To change, or not to change!!??
Old Apr 22, 2008 | 03:58 PM
dwright69's Avatar
I need to really change this tranny (700R4 with 109K miles) fluid, but....I've been told that completely swapping out the fluid and filter will actually make the trans run rough and will shave life off the trans. It was recommended that I get a "power flush" instead and it will be a lot better and less headache!! ??
Old Apr 22, 2008 | 04:02 PM
402 GTA's Avatar
Car: 86 GTA
Engine: 402 cbb
Transmission: th350
Axle/Gears: 9" 3.50
Re: To change, or not to change!!??
Actually the "Power Flush" is what will mess the trans up, it can loosen dirt and other stuff that could cause valves to stick and restrict passages. The best thing to do, would be to just drain what you can by removing the pan and replace the filter and fluid you were able to remove by dropping the pan.
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
