700r4 shift kit???How to install how does it work??
Old Apr 30, 2008 | 01:00 AM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
I'm in the middle of my B&M megashifter install and reading that without a shift kit it doesn't really improve shifts, just makes it funner. I was wondering how does a shift kit help and how is the install?thanks.
Old Apr 30, 2008 | 07:03 AM
squeeezer's Avatar
Car: 5 cars
Re: 700r4 shift kit???How to install how does it work??
a firmer shift
1.is a performance gain=faster shift
2.adds longevity=higher line pressures=less slipping changing gear
3.very simple install
as far as the megashifter
i put one in as well the main reason is cause i could not manually shift from 1st to 2nd withought going past 2nd and directly into 3rd
so greater shift control in manual mode
can i also recomend getting the 2-4 corvette servo as well=better/crisper 3rd gear shift all work is done outside the trans for this one
Old Apr 30, 2008 | 07:30 PM
Pro Built Automatics's Avatar
If you use my kit, it has the Corvette servo, the setup for a smoother 1-2 part throttle shift, new accumulator pistons, seals and pins, larger boost valves, Viton D-rings, Torlon checkballs, etc. Go to https://www.700r4l60e.com/store/prod...&cat=65&page=1 This is the most complete TransGo Shift kit out there. Dana
Old Apr 30, 2008 | 07:40 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
sorry to jack this thread, but i want to buy a corvette servo.. where can i get one for a reasonable price?
Old Apr 30, 2008 | 07:46 PM
squeeezer's Avatar
Car: 5 cars
i got mine in the tci manual valve body kit
wish i could help ya
Old May 1, 2008 | 12:03 AM
C305's Avatar
Car: 91 camaro vert
To install these parts and the corvette servo is it done by dropping the hole tranny or just taking the pan off. I dropped my tranny to install B&M torque converter and don't wanna go through that again.Thanks for the replies.
Old May 1, 2008 | 06:04 AM
Engine: Vortec 357
you just drop the pan then work on the valve body
Old May 3, 2008 | 09:20 PM
C305's Avatar
Car: 91 camaro vert
Does anyone know what i have to do to replace the spindle for the shift lever on the side of the tran that moves to switch gears I think i tightened the lever onto the spindle too tight and it won't move smoothly.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
