Car downshifts at 35+ when letting off the accelerator?
Old May 3, 2008 | 12:21 AM
T4Revan's Avatar
Car: 88 Formula, 89 Firebird.
Engine: 355 V8, 2.8L V6
Hi guys, I have yet another problem with my 'bird and no idea where to start fixing it.
Here's the prob: When driving at 35+ the car will downshift as soon as I let off the accelerator, and a second after I start accelerating it will upshift again. But when in overdrive this problem doesn't occur, it also didn't happen this past monday when I had the heat on. Anyone have any ideas? Thanks to all!
Old May 3, 2008 | 11:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Car downshifts at 35+ when letting off the accelerator?
It this possibly the TCC unlocking & locking that you feel? The TCC will unlock with the foot off of the go-pedal (coast release). And lock again once the pedal is pushed on even a little bit.
Also, in 4th, the overrun clutches are not applied. With this the vehicle keeps on rolling. There isn't any engine braking in 4th. Which does happen in 1, 2, & 3rd gears.
RBob.
Old May 21, 2008 | 03:13 PM
T4Revan's Avatar
Sorry for the late reply, been alittle busy with work (can't believe it's almost been 3 weeks since I posted this). After some googling it appears it is most likely the TCC, but is it normal that it will only lock and unlock after the car is running for a min or two?
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
