a little help with gear change and speedo gear
Old May 4, 2008 | 01:20 PM
92orangestripes's Avatar
Car: 2000 expedition 5.4
Engine: .020 over 350, 9.5.1 comp,
Axle/Gears: 3.27 aussie 9bolt
ok, i need help, i swapped a rear end from a 90 iroc with 3.27 gears into a 92 rs, it had a drum rear with a 2. 7 d something gear, my question is(ive heard that you have to change the speedo plastic gear in the 700 because theres no cable for the speedo,????) how and where if this is true do i find this gear on the trans, location, removal, anything would help. thank you
Old May 7, 2008 | 02:45 PM
paulbuiltbird's Avatar
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
Re: a little help with gear change and speedo gear
You'll need to find out what speedo gears you have. You can check this by removing your speed sensor and looking at the gear on it and the gear on the output shaft. If you go to the web site for PATC (they sell trans parts) they have a chart that will tell you what gear you need based on rear end ratio & tire size.
Old May 8, 2008 | 01:38 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
this board for "3.27 speedo gear" and all will be revealed to you.
Old Jun 16, 2010 | 08:12 PM
sorry i forgot to say thanx, it worked out great,
junkcltr
Aug 2, 2019 11:12 PM
jklein337
Sep 19, 2018 06:23 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
jbd1969
Aug 17, 2015 07:06 PM
