tranny problem need help
Old Jun 11, 2010 | 11:48 PM
matthewyoung.71's Avatar
I have a 91 firebird with a 305 t.b.i and a 700r4. the tranny shifts fine until the service engine light comes on then it acts like it slips. i can pull over shut the car off and start it and it is fine until the light comes back on. i need help don't want to rebuild the tranny if i don't have to.
Old Jun 12, 2010 | 01:51 PM
gmonly's Avatar
Car: 88 chevy k1500 reguar cab, 8' box
Engine: super duty TBI 350
Transmission: 4L80
Axle/Gears: posi 3.73
Re: tranny problem need help
what is the trouble code(s), that will help some
Old Jun 13, 2010 | 07:32 PM
tried reading codes but buddy has a code scaner at the mechanic place he works and it won't connect with my computer
Old Jun 13, 2010 | 10:50 PM
gmonly's Avatar
Transmission: 4L80
his code reader is probably a obd2 (96 and up), you need a obd1 code reader (95 and older)
Old Jun 15, 2010 | 10:20 PM
i used a genesis obd 1 scanner. and the only thing i can think of is the guy before me put the wrong pcm in it. but i don't know if you can even do that. i adjusted the t.v. cable and it seemed to help for maybe 10 min of driving and it was back to the same thing
Old Jun 15, 2010 | 10:49 PM
gmonly's Avatar
Transmission: 4L80
disconnect the battery for about 10 minutes, that will clear the codes. see if it helps, if there is something wrong, the code will come back.
i do not think another pcm would work right, they are coded for certain vehicles. a wrong one would either make it (the moter) run real bad or not run at all.
if it happens again, unplug the wires from the trainy (not the speedometer wires), drive it, if it runs good, then the trainy would need some work done to it.
Old Jun 15, 2010 | 10:58 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
only tcc is controlled by the ecm. at what speed/gear do you notice the problem?
Old Jun 16, 2010 | 08:35 PM
it usually starts to act up if i kick it down to pass a car. it will make the light come if you put it down a gear with the shifter and if you put it to the floor. but it doesn't do it every time. one of my buddies thought i might hae a servo sticking. it seems like it is mainly drive and overdrive that does it. also noticed when the service engine light isn't on and i am town driving it seems like it surges a little bit. and when the light comes on and the tranny starts acting up my motor doesn't rap up right and it will start to back fire
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
