Speedo Drive Gears?
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
Speedo Drive Gears?
ok I am going from an 85 z28 3.08 rear end to a 98 LS1 3.42 rear end and want to keep my speedo as accurate as possible.
I found this information on the site already:
3.23's up require a blue 7-tooth drive gear, plus the following driven gear:
18 tooth (p/n 3987918) Brown = 3.23
19 tooth (p/n 3987919) White = 3.42
20 tooth (p/n 3987920) Blue = 3.45
21 tooth (p/n 3987921) Red = 3.73
22 tooth (p/n 3987922) Gray =3.77
3.08 has an 9-tooth drive gear.
So my question is, can I keep the 9 tooth and if so, what driven gears do I use to match to the 3.42?
Or, what is the part number for the 7 tooth drive gear? (I have a 19 tooth driven gear sitting here on my desk anyways)
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo Drive Gears?
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Look under TH350 (Yes, I know you have a T-5):
JamesC
JamesC
beachrodder
Aug 7, 2015 04:27 PM
