700r4. What is this?
Old May 7, 2008 | 04:32 PM
Pnormandin's Avatar
Let me describe:
If you are looking at a 700r4 on the side where the TV cable connects, just below that there are 2 outlets that usually have bolts in them. Can anyone tell me what they are for? Are they for an external cooler or something? They take special bolts that have threads just a bit under the cap and then smooth the rest of the way. I just bought this tranny and noticed that I only have 1 bolt the other is plugged with a plastic cap and I don't know where to begin looking for this bolt. If I cannot find those bolts do you think just using regular bolts with sealant would work? I am not sure if this is under alot of pressure.
Sorry for no picture and thanks for your help.
Old May 7, 2008 | 08:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 700r4. What is this?
they are probably the cooler lines, you NEED to run a cooler period.
Old May 7, 2008 | 09:30 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
Those are pressure taps, they were only on 89 and older models
ZZ3Astro
Aug 13, 2019 12:57 AM
stalkier
Dec 6, 2015 11:25 PM
IROCZ1989
Sep 4, 2015 11:54 AM
fbirdroller
Sep 2, 2015 10:27 PM
stalkier
Aug 21, 2015 01:54 AM
