plugging 10 bolt vent hole?
Old May 17, 2008 | 12:39 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I just bought a 10 bolt with a 3.42 and ls1 disc conversion... it doesnt have the vent on the top passenger side..can I plug that hole with a rubber plug from the auto store or does it have to be vented?
Old May 17, 2008 | 01:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: plugging 10 bolt vent hole?
It should be vented. You can pick up simple vents that prevent dirt from entering the diff.
One of these is what you need depending what size the hole is.
http://www.jegs.com/i/JEGS/555/60117/10002/-1
http://www.jegs.com/i/JEGS/555/60116/10002/-1
Old May 17, 2008 | 11:15 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
It you don't vent it, oil will be forced past the seals from the pressure that will build when it gets hot.
Old May 18, 2008 | 01:36 PM
Pat Hall's Avatar
Simple and cheap solution. Just take a pair of pliers to the junkyard and yank one out of a junk rear, put it in your pocket, and take it home. They just press in and they're pretty easy to pull out with a pair of pliers.
Old May 18, 2008 | 03:11 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
I like the way ya think.
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Elliswon
Aug 10, 2015 12:33 PM
