clutch/tko issues
Old May 17, 2008 | 06:43 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
clutch/tko issues
so i installed a tko 600/ lakewood bellhousing on my car, i've been driving it around and it's been working great, i know my slave cylinder has a small leak, so the other day i went to back into a parking spot and reverse grinded like hell and it was hard to get in 1st, i found very low fluid in the resevoir, so i filled it up and changed the slave cylinder out and bleed it, now i'm having the exact same symptoms, start car put in another gear throw it into reverse and it grinds, 1st gear is hard also, the car does not move in gear with the clutch disengaged, question is, the throwout bearing with the car off should the bearing be right on the pressure plate? or off of it?
Old May 17, 2008 | 11:12 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: clutch/tko issues
It should be off it, barely. Otherwise it would always be spinning.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
