Will 4th gen gears work in a 1988 10 bolt?
Old May 20, 2008 | 04:26 AM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I am getting a zexel posi unit from an ls1 that has 3.42's on it. Can I use these gears or do I need to put my old gears on the new posi unit? Will my old gears even fit on the zexel posi unit?
Old May 20, 2008 | 05:49 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Will 4th gen gears work in a 1988 10 bolt?
Yes, if you have a 3 series carrier and the it will work with LS unit. All 10-bolt gears are 7.500/625 dia for both 3rd & 4th gen cars. On a side note: make sure axle spline is correct with that LS if that is being changed.
Old May 20, 2008 | 12:04 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
An '88 10-bolt will most likely have 26-spline axles in it, while the 4th gen posi unit will definitely have 28-spline axles. They are not compatible. You'll need to get 28-spline axles for a 90-92 thirdgen 10-bolt as well.
Yes the gears will fit on the posi-unit, but the axles are your bigger problem.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
dhonda200
Aug 11, 2015 11:50 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
