B&M mega shifter 2ft cable or 5 ft
Old May 20, 2008 | 12:08 AM
C305's Avatar
Car: 91 camaro vert
Engine: 350,113heads,ccxfi260, slp shortys
Axle/Gears: 3.23s posi discs
Hey there just wanted to know why do people switch the 5 ft cable that comes with the shifter for the 2ft cable. My install hasn't gone smooth i keep adjusting and either my shifter will not go into first gear after adjustments it will go into first but not park and back and fourth after many adjustments.
Old May 20, 2008 | 08:12 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: B&M mega shifter 2ft cable or 5 ft
5ft cable in my car.
Do you have the cable in the correct hole in the tranny shift arm? To my knowledge, none of the aftermarket shifters will work with the stock linkage arm on the transmission. You should be using the front hole in the supplied lever on the shifter.
Old May 20, 2008 | 01:09 PM
C305's Avatar
Car: 91 camaro vert
I got the cable right in the front hole got the cable looped ontop of the tranny.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
AUZ28
Oct 3, 2015 06:28 PM
ndndndnd
Sep 28, 2015 08:00 AM
