1987 Spline Count
Old May 20, 2008 | 07:56 PM
f7firecat's Avatar
Car: Camaro
Engine: LB9
1987 Spline Count
87 LT with a 2.8L, open rear end, 342 gears. How many spline axles?
Old May 20, 2008 | 08:00 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 1987 Spline Count
Welcome to TGO! They should be 26. They didn't go to the 28 spline axles until 89-90.
Old May 20, 2008 | 08:31 PM
f7firecat's Avatar
Car: Camaro
Engine: LB9
Thanks Ozz, great site. Next question 7.5 diameter Ring Gear?
Old May 20, 2008 | 09:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Only if it's a 10-bolt. I don't remember the 9" ring gear size off the top of my head. I think I remember reading that it's a 8.85" or so but don't quote me on that.
Old May 20, 2008 | 10:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Count the bolts on the cover. 10 bolts = 7.5/7.625 10 bolt. Around 1986 the 7-1/2" ring gear was upgraded to 7-5/8". Parts are all interchangeable but it's still called a 7.5" diff.
If your rear cover has 9 bolts and a rubber plug in the cover then you have a 7-3/4" Borg Warner 9 bolt. Stronger than the 10 bolt but only available from 87-89 and parts are from Australia.
With a 2.8L, it's very unlikely you have a 9 bolt unless a previous owner swapped it in. The 9 bolt was a performance option to the Z28 cars.
Old May 21, 2008 | 06:49 AM
f7firecat's Avatar
Car: Camaro
Engine: LB9
It is a 10 Bolt. Question, I plan on changing the carrier to a posi using the same existing ring gear, will the 7-1/2 or 7-5/8 342 ring gear fit on any 10 bolt 3 series carrier or do I need to order a 7.5 or 7-5/8 carrier.
Old May 21, 2008 | 07:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes, the ring gear will fit. Just make sure your axle shaft spline count is the same as the new carrier.
Old May 21, 2008 | 09:55 AM
f7firecat's Avatar
Car: Camaro
Engine: LB9
Thanks to all who shared some answers!
David Frans
Oct 31, 2015 08:12 PM
darwinprice
17
Oct 11, 2015 11:51 PM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
