Looking for aftermarket manual trans to replace my T-5
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Is there any trans out there that is a direct fit? I ask because I have a umi tunnel mounted torque arm that mounts to the crossmember and i dont want to have to buy a new one... (too damn expensive) I heard getrag used to make a direct fit 6 speed... The one thing i dont want to have to do is replace that crossmember and torque arm.. Any suggestions?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Looking for aftermarket manual trans to replace my T-5
you have the t5/700r4 UMI crossmember? how good are your basic fab skills? I have the same crossmember and im using it with my tko600. All you need to do is make some spacers for each side crossmember mount, 1/2" thick total on each side. I used 2 - 1/4" thick pieces of aluminum on each side, it was just easier for me. Make them the same size as the mounting pads and drill/ream/file out the slots for the holes. Your done. the trans kit will bolt right in, just have to change the trans yoke on the driveshaft. no biggie. just make sure the bolts are long enough.
I can't get pics for you right now, the car is in the shop, but its really simple, i made them with a drill, sawzall and a round file. took maybe 2 hours at a leisurely pace.
fortespartsconnection sells the tko and the conversion parts, ie adapter plate, yoke, ect. it will cost about 2500total, what are you looking to spend on a trans vs just buying a new crossmember?
or its a used t56 and a new crossmember.
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
not tryin to steal thread but 86ta how is that tko you like it a lot...my 5th gear just went out on my t5 to much torque with 350...an i need to get a replacement something that can handle the power been thinking about a tko but havnt heard to many things about them seems most ppl run the t56 instead
Engine: 350sbc
86ta i cant find the link u posted can you link it plz the fortespartsconnection i googled it and im not finding it
Car: 1986 Iroc-Z
i was looking at that earlier... (website) $2500 is outta my price range.. I dont see the need for the tko-500 right now because i just have a 305... i plan on puttin in a 350 down the road but i think it would be cheaper o just get a world class and have it rebuilt. i think i'm just going to get a W/C t-5 and ha it rebuilt with mustang internals... (stronger)
1992 Trans Am
May 10, 2023 07:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
