One way shifter cable
Old May 28, 2008 | 07:07 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Ok so I replaced my shifter cable and the bracket that goes to the transmission pan (it was missing). Hooked up all the linkage and now I got a problem. I can shift from Park to every gear after up to 1 or 2. But when I want to shift it forward to D R N etc. the cable bends and it doesnt push the lever forward. Do I have this thing mis adjusted or what?
Heres pics of what its doing incase you dont get what im saying
Attached Thumbnails One way shifter cable-700r4a.jpg   One way shifter cable-700r4b.jpg
Old May 30, 2008 | 09:16 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: One way shifter cable
ttt
Old May 30, 2008 | 05:35 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
where did you get that shifter cable and what is all the white stuff around the housing. that thing looks like it is broke.
Old May 30, 2008 | 08:11 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
shifter cable is new from advance auto, its exactly the same as the old one i had. the old one was frayed. The white stuff is the plastic. The bolt goes thorugh it and it pivots on that.
Old May 30, 2008 | 09:08 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
check at the shifter ..... sometimes the ears that hold cable in place will break and you'll be pushing the hole assembly forward instead of just the cable ...... i know cause need to replace mine and i have to hold the cable when i push shifter forward
Old May 30, 2008 | 10:59 PM
87zjeff's Avatar
no, i was referring to the putty looking stuff where the cable housing mounts to the bracket.
also, a new cable shouldn't be coming apart like that one is in the second pic. looks like the "new" cable is broke.
do yourself a favor and get a dealer one. those aftermarket ones are crap. i learned first hand before i got my megashifter.
part number should be: 10232154
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
