spare rear, $50, turns out richmond posi!
Old May 30, 2008 | 10:59 AM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
so just like the title says, i bought a rear end from an 84 berli, and got it home and pulled the cover and the fluid was just about brand new, still had a green tint to it from the additive i suppose, anyways the diff looks brand new also, the gears say Richmond right on them, but the diff doesn't, so how do i tell what it is? i can see that its a clutch type posi, and the tag was still on the rear end saying to use limited slip fluid, and the gears puzzle me too, i turned the wheel one full rotation, and the drive shaft turned exactly twice, i dont get it? whats the ratio? the gears just say Richmond with a ton of numbers around the ring gear, but no ratio, any ideas?
Old May 30, 2008 | 12:11 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: spare rear, $50, turns out richmond posi!
You sure about that? That would be 2.00:1... I dont think that was a ratio that came in these cars, or that someone would put in... I think it should be 3.08:1, 3.23:1, or 3.42:1 for a stock 84 berlinetta, depending on motor and transmission combination. I could be wrong on that, but Im pretty sure its not a 2.00 gear. Way too high of a gear for a normal application. But who knows...maybe someoen was gonna top speed it?
When you want to check gearing..the CORRECT way is to turn the pinion. And watch the ring gear. It will take away any descrepencies. Maybe the posi was slipping or "unloading". Mark the ring gear with some paint or tape, then rotate the pinion/driveshaft until the ring gear makes one full revolution. The number of times the driveshaft turns at that point is your ratio.
J.
Old May 30, 2008 | 12:12 PM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
cant really answer your questions...but nice score...im very jealous lol...thats like winning the lotto
Old May 30, 2008 | 01:38 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Just count the teeth on the ring and pinion gears and divide the two numbers to get the exact ratio.
Old May 30, 2008 | 02:49 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
That's the best way of doing it.
Old May 30, 2008 | 05:36 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Every ring gear made has the p/n, Mfg and the number of gear & pinion teeth stamped on it.
Old May 30, 2008 | 05:43 PM
Car: 85 camaro
Axle/Gears: 342
thats exacty what i thought, 2.00:1..... what? haha thats what i said, anyways im sure it only went twice, and i look on the ring gear and it says RICHMOND with a bunch of numbers all together on it, prolly about 15 digits, i cant really make sense of it, i guess ill just count the teeth, that'll be fun.... and yea it was a pretty sweet deal
Old May 31, 2008 | 10:24 AM
Car: 86 Trans AM
Pff....counting teeth... Who likes to do that
Yes that will work too. But the easier way is by turning the pinion in my opinion. You wont get 3.xx..but you'll be able to tell. It will be a common ratio. 3.08, 3.42, 3.73 etc etc... My point was more about turning the wheel to count pinion turns. It doesnt always work. Gotta turn by the pinion.
J.
Old May 31, 2008 | 11:24 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Just write down all the numbers you can sse on the gears themselves. once you do that give Richmond's tech line a call then you will know FOR SURE what gear ratio you have and also what series carrier you have. Done deal
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
