Line press fluctuating 700r4
Old Jun 5, 2008 | 09:55 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Connected a line press gauge to port just above the shift shaft. At idle and when driving at low throttle settings, the press is steady, as I start opening the throttle, the needle on the press gauge rises (which would be normal) and starts fluctuating rapidly abt 20-30 psi. At first, I thought there was still air in sys (fresh rebuild), but it doesn't seem to be getting any more stable as time goes on. It drives and shifts just fine.
Is this normal?
Has anyone driven around with a press gauge connected and noticed the same issue?
Old Jun 9, 2008 | 12:17 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: Line press fluctuating 700r4
Has anyone driven around with a line pressure gauge connected and saw steady readings?
Old Jun 10, 2008 | 12:58 AM
Pro Built Automatics's Avatar
As the rpm rises past 2,500 rpm it should stabilize. What are you seeing at the higher rpm's?
Old Jun 11, 2008 | 01:32 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
It will be next week bwfore I get a chance to re-connect the gauge and take it for a spin. I'll let ya know happens.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
