1986 Z28 Camaro - Need Help Please Read -
I just bought a 1986 Z28 Yellow Camaro , She is a beauty but so far I have 3 main things I really would like to get fixed asap but I was curious if anyone might know the problem so the mechanic doesn't try and rape me .
First Problem - She starts up fine and she sounds great but when I put it to a stop or for instance am at a stop light it starts to slowly die down and then eventually stalls , So If I want to prevent this then I hold the break down and rev it .
Second Problem - My speedometer fiddles , for instance when I am driving and I am at 30mph it will bounce between 30mph and about 35ishmph and its even worse when I am at 80mph it will jump from 80mph to 90mph .
Third Problem - When I pull it out of Park and go from Reverse it will jerk a little bit and then go to Drive it will jerk again .
Answers - If you can please give me your feedback It would be much appreciated .
Sincerely - Joshua
You can also reach me at -
Aim - Jokerslye
Yahoo - Jokerslyes@Yahoo.com
Msn - Jokerslye@Hotmail.com
Email - Jokerslye@Gmail.com
Sincerely - Joshua
Aim - Jokerslye
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1986 Z28 Camaro - Need Help Please Read -
While you have the cluster out:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I assume it is a tune port 305. If not sounds like you need a carb rebuild.
Car: 85 Z28
For the first problem, screw a fuel pressure gauge onto the fitting and take it for a drive. Could be as simple as a dirty fuel filter.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
