Tips for swapping 9 in center section
Old Jun 19, 2008 | 11:07 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I want to swap my 9 inch center section with rear end in the car.
Any tips?
Car is on jackstands.
My main question is how to put the new unit in while keeping my fingers and not dropping it on my face.
I thought of making a jig to rest it on my jack.
Please chime in with best practices!
Old Jun 20, 2008 | 08:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Tips for swapping 9 in center section
Rest it on the jack, and use a prybar/screwdriver to slide it slowly off the studs. Don't pry it hard, you may damage something, but that way you can slide it off slowly enough to keep it in control, and maybe keep a hand on top to secure it too.
Old Jun 20, 2008 | 08:41 PM
EvilCartman's Avatar
Car: '82 Z28
I've just rested it on the jack in the past. I've seen an adapter for a floor jack that bolts to the center section, can't remember who has them.
Old Jun 20, 2008 | 10:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's only about 40-50 pounds. I just lift mine up and pop it in and I don't have an aluminum center section yet.
Old Jun 21, 2008 | 09:34 PM
SDIF's Avatar
Thanks for all the replys!
I made a jig to bolt to my jack.
I will slide it in.
Ghettobird52
Apr 21, 2020 08:44 PM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Hello, Michael
Aug 20, 2015 03:19 PM
