HELP! 700r4 to th350 swap.
Old Jun 21, 2008 | 02:53 PM
CamaroCarnage's Avatar
well my 700r4 bit the dust, so im swapping in a th350 out of a impala. the 350 doesnt have the torsion bar mounts on the tailshaft and the tranny is 3 inchs shorter. and what about the crossmember?? any input GREATLY appreciated!
Old Jun 21, 2008 | 03:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: HELP! 700r4 to th350 swap.
Easiest way is with a new aftermarket torque arm kit. The new torque arm will come with a proper crossmember and the torque arm will attach to the crossmember instead of the tranny.
If you can find a 82-83 third gen that came with the 200c 3 speed tranny, that driveshaft will fit with the 6" tailshaft TH350. The other option is to find and use a long 9" tailshaft TH350 so that the 700R4 driveshaft will fit.
The cheapest route is to buy a swap kit. It provides an adapter for the tranny mount and an adapter for the torque arm. This is a poor and really cheap way of doing the swap and isn't always recommended.
You'll also need a manifold vacuum source for the modulator valve.
Old Jun 21, 2008 | 06:46 PM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
where u at i just swapped from 350 back to 700 and my drive shaft its too long wanna swap it is about three inches too long
$750 L98
Feb 1, 2025 02:25 PM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
