Lock up TC question
Old Jun 21, 2008 | 08:16 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Lock up TC question
I have an '87 GTA with the 700r4 and according to my research the 87's came with 3:23 gears. I notice when I am at 60mph the tach reads around 1950 RPM, does that seem high? From a dead stop there are only three RPM drops, shouldn't there be four? I haven't had this car very long so I don't have any idea what may be unplugged or unhooked. Any suggestions what I should look for?
Old Jun 21, 2008 | 08:29 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
Re: Lock up TC question
the 700r4 cant shift into OD at WOT(i think safety thing)..but can be modded to remove that.....your tach is prob a lil off
Old Jun 21, 2008 | 08:48 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
That's not WOT, I'm pretty easy on it. At idle my tach seems right, about 700 rpm.
Old Jun 24, 2008 | 12:03 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Four gears, but only three intervals: first-to-second, second-to-third, third-to-fourth.
Old Jun 24, 2008 | 09:58 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
But wouldn't the fourth interval be the TC locking up? Or could the TC be locking up at the same exact time it shifts into 4th? When I'm cruising at 60mph and I let off the gas, and then press it again, I should be able to see (and hear) the TC unlock and then lock again. I'm not seing that.
Old Jun 24, 2008 | 07:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe, but you might have your foot far enough into it that the TCC isn't locking up, or the lock-up could be coincident with a gear change. You should be able to make the TCC lock and unlock at some point, though... try grounding the TCC pin on the ALDL.
Old Jun 25, 2008 | 01:52 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
To see if the TCC is locking, get on the highway at cruising speed.
After a few minutes, give gentle throttle and observe the rpm. Then, step on the brakes just hard enough to trigger the brake lights, but not slow the car in any way. This will unlock the converter and you should see the RPMS increase by about 200.
Hope this helps.
Old Jun 25, 2008 | 02:34 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Hope this helps.
I tried that, nothing changes. The TC is definitely not locking. I think something was unhooked somewhere, I just don't know where to look. My daily driver does like it's supposed to (like you described), but the GTA doesn't.
Old Jun 25, 2008 | 02:41 PM
Toehead's Avatar
Trace the wire from the 4 prong plug.
It will have three wires. One is +12v, One is 4th gear signal and should ground when the car shifts into fourth, and the other is lockup.
Ground the lockup wire to test the convertor. IIRC, it is a blue wire.
Old Jun 25, 2008 | 03:00 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I'll look for that.
Old Jan 31, 2009 | 04:53 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Okay, I have updates. I tried grounding the ALDL pins, still no lock up. Today I dropped the pan and changed out the TCC solenoid, took it for a spin and the TC still doesn't lock up. The only thing I can think of now is the wire coming from the ECM must be shorted somewhere. I'm also running a 180 stat, but surely that's warm enough for the converter to lock? I suppose the converter itself could be bad, but wouldn't that cause shifting problems?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cameeeero
Sep 18, 2015 04:00 PM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
