LS1 T-56 Swap
Car: 1987 Chevrolet Monte Carlo SS
Engine: ZZ4 - 350
Transmission: 700 - r4
Axle/Gears: 3.73 posi
LS1 T-56 Swap
ok guys, hoping someone here has done this before , and can help my with a parts list that I'll need. This is what I have......
I acquired a T-56 out of a LS1 01 Camaro. I currnetly have a 87 Monte Carlo SS w/ a ZZ4 GM performance 350 motor
I've heard that the bellhousing wont match up being that the tranny is from an LS1....Could I swap the bellhousing to one out of a LT1? Would the bolt pattern match up, is that the only problem with it?
Flywheel? any recomendations and sizes that will work for me.....Same with the Clutch
I have the Hydraulics that came with the transmission, anything else that I may need to swap?
Finally this isnt going to be a track car, although I wont be driving it like a 80 yr lady....it will get a work out from time to time, but I'm not planning on beating the crap out of it....
Any help would be GREATLY appreciated.....thanxs in advance
Houlie
Houlie
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: LS1 T-56 Swap
As far as I know, the tranny will not work because the input shaft is also different.
Did you see the Sticky thread at the top of the page?
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: LS1 T-56 Swap
you have to change the front cover and input shaft or spend 500 bucks on a McLeod modular bellhousing. Sorry those are the only 2 options.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: LS1 T-56 Swap
or option 3 use an adapter and pilot from mccloed and bolt it to your t5 housing.
If you dont have a t5 then just sell it and get an lt1 tranny. it would prolly be cheaper.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Hello, Michael
Aug 20, 2015 03:19 PM
