Any Difference of a Camaro T56 to a Corvette T56?
Old Jun 26, 2008 | 01:48 AM
Demon_Eater's Avatar
Car: 91 Camaro RS
I finally got my hands on a T56, out of a 96 Z28, complete set,
I do have to get a new crossmember, and get a master cylinder, but other then that, it should work.
My question is, is there any difference of a Camaro T56, to a Corvette T56?
is the torque or hp different? (I know I didnt really word that right, but you know what I mean.)
Thanks,
Tim
Old Jun 26, 2008 | 11:09 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Re: Any Difference of a Camaro T56 to a Corvette T56?
should be the same hp/tq atings for both...the only difference i knowof is the C5 and C6 t56 is monted in the rear with the transaxle, and has an internal slave cylinder... but still the same hp/tq ratings, up to 450 ft/lbs... i do not know if you can use a C4 slave or master cylinder, but you may be able to use a C4 flywheel, not the ones with the ZF trans...
Old Jun 26, 2008 | 04:29 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
take a look at this, should answer your question
http://www.rsgear.com/articles/2002_07.pdf
Old Jun 26, 2008 | 09:06 PM
Car: 91 Camaro RS
Thanks, that helps alot
A friend that has a Corvette T56, said it looks the same as his, but he put in a lot of different parts, but I was wondering if the tq or hp were different.
Thanks once again,
Tim
Frozer!!!
Jan 19, 2024 04:55 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
