Help with tranny ! ! !
Old Jul 27, 2000 | 08:10 PM
86kidsroc's Avatar
I pulled my motor last week to do some work on it,and when I put it back in the trans won't go into reverse or any of the drive gears ! I bolted the torque converter on and slipped the tranny in,hooked everything up, and nothing. Here's some backround, It's a 700r4 w/a 3500 stall 9". Not sure of the manufactuer. It shifts into park and nuetral and clicks through all the detents okay. The cooler lines aren't blocked. I pulled the pan and the fluids bright red with no signs of metal shavings anywhere. I've previously yanked the computer,so there's no electrics on the trans. The trans worked perfect before I pulled it out of the car to do the motor work.
I'm stumped ! Any help would be greatly appreciated. Thanks
I posted this in trans board also.
86 iroc
388ci.
brodix
victor jr.
750 edelbrock
3.5 oval true duals
Old Jul 28, 2000 | 07:06 AM
Baz89RS's Avatar
First of all, where did you get that 9" converter, most that advertised a stall of around 3500 are 10"... I thought that 9" converters aren't streetable on 700R4's ??
Old Jul 28, 2000 | 02:12 PM
86kidsroc's Avatar
It came with the car,that's why I don't the make.
Old Jul 28, 2000 | 05:35 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Whooooaaaa, back up. You bolted the Torque conveter up to the flywheel and then installed the tranny? You just smashed your pump, and probably ruined the conveter. Sorry dude.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
About Me
Old Jul 29, 2000 | 02:23 PM
86kidsroc's Avatar
Live and learn and $200.00 lighter!
Old Jul 29, 2000 | 02:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I read your post on the Transmission board, and I know you ruined the converter, but the pump would be the first to go, so if the converter is ruined, then the pump is 99% chance of being ruined also. I would hate for you to replace the converter and bolt it all back up and still have nothing. do yourself a favor and make sure that the rotor inside the pump is not broken. You may be able to see it well enough if you remove the Torque Converter Seal (make sure you get a new one.). Good luck.
Savannah, GA
'97 Bonneville SSE
About Me
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
