Starter help!
Old Jul 3, 2008 | 09:59 PM
racechevy7's Avatar
Starter help!
I have a 1991 Rs was a 305 5 speed car. Original trans still there. I installed a 350 ci engine, completed the install and now cannot find a starter that will work on my block AND in the bellhousing! The block only has offset holes to mount a starter but the only starter I can find to work in the 5 speed bellhousing for the 153 tooth flywheel has a straight across bolt pattern. Please help, part #'s and ideas are much appreciated.
Old Jul 3, 2008 | 10:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Starter help!
Have the block drilled and tapped.
Old Jul 3, 2008 | 10:31 PM
racechevy7's Avatar
Re: Starter help!
Is that my only option? I found a picture of a starter for a 1972 400ci w/ a manual transmission that looks like it might work.....offset holes and for a 153 tooth flywheel.
Old Jul 4, 2008 | 12:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Starter help!
If it has an offset bolt pattern, it's not for a 153 tooth flywheel.
Drilling and tapping the block or not using a T5 are your only options.
Old Jul 4, 2008 | 04:49 AM
racechevy7's Avatar
Re: Starter help!
Another one......1991 s10 4.3 manual transmission starter, wouldn't this have also used the t5? It has an offset bolt pattern and would be the same as a v8. And you are saying that there is NO starter with an offset pattern that will fit a 153 tooth flywheel? All 400 ci blocks only have offset holes so there must not be ANY way to use a manual tranny with a 400ci engine, correct?
Old Jul 4, 2008 | 09:41 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Starter help!
There is no starter that will fit the offset holes on your block, that will work with a 153 tooth flywheel.
You can use a manual transmission with a 400, just not with the small flywheel, unless you drill the block for the starter.
Old Jul 4, 2008 | 02:33 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Re: Starter help!
park on hills good luck w/o drillin block. cost is prob $70-140 (1-2 hours of work)
Old Jul 4, 2008 | 03:54 PM
racechevy7's Avatar
Re: Starter help!
Any other options? Different flywheel? modify the bellhousing, etc. Can the block be drilled in the car? I wouldn't think that cast iron block is easy to drill. You said manual transmission can be used on a 400 right, but is that a t5 manual or an old style 4 speed?
Old Jul 4, 2008 | 04:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Starter help!
Cast iron drills like butter. Doing it with the necessary precision is harder.
Old Jul 4, 2008 | 05:30 PM
racechevy7's Avatar
Re: Starter help!
Will this need to be done at a machine shop or is it possible at home? Anyone on here done it? Thanks, Oh yeah, having a new car with over $5000 in a new engine that you cant start SUCKS!!!!
Old Jul 4, 2008 | 05:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Starter help!
With proper care and attention, it could be done with difficulty at home.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
