no idea what this is...
I have a 92 borg-warner T-5(closes ratio they made probibly, it was custom rebuilt for the guy who raced it and i could tell had been taken apart at one point in time becuase the seals did not look factory..aka RTV hanging out seems) well anyway their is a mysterious tube that came up out of the passenger side gearbox and seemed to lead nowhere. I checked all the manuels (including GM shop) and none gave me any insight into this mysterious tube. Is this normal? is it just some breather tube or was it supposed to be hooked up to something. Thanks in advance for reading this far and any help you might give.
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The vent tube is on top where the extension housing bolts to the main case. If it's coming out from the side, it could just be a custom-made filler tube because it's a major PITA to add fluid to one.
Pete
Pete's Place
Now at HiOutput.com
83 SC...LG4/5-speed from an 84 Z28, 3.42 one-tire-fryer, T-tops, PW, PH, gray interior from an 86 Firebird SE, seats from an 89 Formula, Wheels from an 83 Z28, springs and rear bar from an 84 Z28, WS6 front bar, Hedman Hedders and y-pipe, Dynomax cat-back, .420" lift cam, Accel HEI Supercoil and foam air filter, custom air induction through Z28 hood.....best ET is 14.935@94.14
Pete
Pete's Place
Now at HiOutput.com
