lock up converter in a glide
Old Jul 5, 2008 | 09:18 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i just picked up a build powerglide from a friend of mine but i dont have a converter for it. i have the vigilantie that was on my 700r4 but it is a lock up converter. would i be able to use that one or would it destroy the converter. i would rather find this out now so i could sell the vigilantie that i have now and get another one. its a 3400 stall and has less than 1000 miles on it. i did a search but i couldnt really find the answer i was looking for.
Old Jul 5, 2008 | 09:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: lock up converter in a glide
I'm not sure on the spline count of the 700R4 converters. Does the PG have a factory course spline input shaft or a fine spline turbo shaft? Usually you get a glide converter with glide splines or turbo splines (TH350/TH400)
Old Jul 5, 2008 | 09:55 PM
Car: 84 camaro Z28
Engine: 434sbc
sorry i forgot to mention that it has the fine spline shaft( its from a th350). my converter from the 700r4 slides right on and fully seats with no problem. also i can pull the input shaft out of the stator shaft pretty easily. is this normal for a glide with the th350 input shaft. i dont really know alot about glides. thanks alot for the help.
Old Jul 5, 2008 | 10:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Yes it's normal that you can pull the input shaft out. It's not a TH350 shaft. It's a PG shaft with turbo splines. PG and TH350 parts are not interchangeable.
Powerglide input shafts have 17 splines
Turbo spline shafts are 30 splines
84-97 700E4/4L60E have 30 splines
Pre 84 700R4 have 27 splines
Old Jul 5, 2008 | 10:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
So do all the V6 700R4s, IIRC.
Old Jul 6, 2008 | 08:33 AM
Car: 84 camaro Z28
Engine: 434sbc
oh ok thanks. so would i be able to use my lock up converter. or would it ruin the converter
Old Jul 6, 2008 | 10:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
It should work but just won't lock up.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
