Transmission flush
Old Sep 14, 2000 | 01:32 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
Transmission flush
How exactly do I flush my 700R4? I've heard I'll have to disconnect the return line for that - is it inside the tranny or can it be done without dropping the pan? Somebody please gve me a detailed explanation of this.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Old Sep 15, 2000 | 08:13 PM
ede's Avatar
ede
the lines that go from the trans to the radiator. not sure if it's top or bottom line.
Old Sep 18, 2000 | 11:48 AM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Correct me if I'm wrong but don't the lines from the radiator carry coolant to the transmission? I'm sure it can't be trans fluid.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
Old Sep 18, 2000 | 01:31 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
The lines carry transmission fluid to the radiator and back to the transmission.
Old Sep 19, 2000 | 01:57 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
This is confusing. the radiator carries both coolant and transmission fluid?
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
Old Jun 27, 2003 | 10:24 PM
25THRSS's Avatar
What if you don't have a transmission cooler, or do all third gens have them?
Old Jun 27, 2003 | 11:31 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i could be wrong but as far as i know every car ever made with an automatic tranny has a tranny cooler.. and yes they flow tranny fluid.. not coolant.
Old Jun 27, 2003 | 11:37 PM
25THRSS's Avatar
Thanks for the info. Where exactly do the lines connect to the radiator?
Old Jun 28, 2003 | 10:38 AM
MdFormula350's Avatar
two metal lines on the passengers side of the radiator.
the tranny cooler is inside the radiator and it sealed off from the coolant. so the tranny fluid that runs inside from the two lines goes inside the tranny cooler and gets cooled off by the collant surrounding the tranny cooler.
Old Jun 28, 2003 | 12:16 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
If the fluid is a dark brown color and smells “well done”, it needs to be replaced. Flush the entire system, not just a filter and pan gasket service, which only captures about half the fluid. If you don’t have a flushing machine in your shop, take the vehicle to a transmission shop and have the job done there, minimizing the odds of a come-back.
In addition to fluid breakdown as a result of excessive heat, fluid which has been contaminated with coolant due to a leaking oil cooler is just as detrimental to the operation of the automatic transmission. If the fluid is a milky, pink color you need to flush the system completely. Coolant mixed in with transmission fluid causes the lining material on the clutch disks to flake off and the rubber seals will begin leaking, causing a drop in oil pressure to clutch packs. The result? Transmission failure.
The addition of an external, auxiliary oil cooler is always wise. Put it on and forget about most transmission overheating problems. If the vehicle is used for heavy-duty operation, you need to choose the proper oil cooler for the application.
Auxiliary oil coolers are available from many aftermarket suppliers.
Old Jun 28, 2003 | 05:21 PM
25THRSS's Avatar
Thanks for the info, anyone ever flushed out your tranny by yourself?
Old Jun 28, 2003 | 09:57 PM
25THRSS's Avatar
2 questions. Should I flush it first then drop the pan and replace the filter or should i do it the other way around? Second, when you are putting the pan back on, which side do you put the gasket sealer on? Also, does anyone know which line I should disconnect for sure? Guess thats 3 questions, oh well, lol. Any replys would be much appreciated!
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
bryan623
Sep 19, 2015 10:13 AM
84redta
Sep 19, 2015 09:58 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
