T-56 SWAP
Old Jul 7, 2008 | 07:20 AM
STOLN's Avatar
T-56 SWAP
Hey,
I have heard many things regarding changing the starter to the smaller starter from the 93-97 Camaro/Firebird when doing the T-56 swap. Could someone shed some light on this. Who has done the swap and did you change the starter?
Old Jul 7, 2008 | 07:47 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: T-56 SWAP
I changed from the stock starter to the Summit mini starter when I did the swap. I had a hot-start issue with the stock one and I've never had it since.
Old Jul 7, 2008 | 01:54 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: T-56 SWAP
same with me, kept the stock starter on but had a major hot start issue. Then went with a cheapie ebay mini starter that quit after about 4 months, and then went with a remaned LT1 starter.
So it's not necessary on your parts round-up list, but I'm very happy with the LT1 starter.
Old Jul 9, 2008 | 10:51 AM
STOLN's Avatar
Re: T-56 SWAP
Also what was changed on your ECM PROM? I am going from a 700R4.
Old Jul 9, 2008 | 03:23 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: T-56 SWAP
I didn't change anything and it drives fine sometimes it will die when I engage the clutch on the highway, and I have to pop start it again. I suppose someday I'll need to pick up a chip from an 89 corvette 6 speed car and see if that makes a difference.
Old Jul 9, 2008 | 04:35 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: T-56 SWAP
Guess ill grab an LT1 starter next time i order some stuff.
Old Jul 11, 2008 | 11:35 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: T-56 SWAP
I reused the stock starter that came with the 700r4. I had to grind a little off the nose of the starter and some from the bellhousing to get it to fit. I haven't had any hot start issuse. It works fine for me.
As for the PROM I just changed the flag from automatic to manual. Some say that doesn't actually do anything. It seems to make a little difference but was hard to tell since my car ran fine without any changes. Again some have better luck than other depending on the program.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
cRoe4
Aug 7, 2015 08:46 PM
