how do you know your trans mount is gone?
Old Sep 15, 2000 | 10:25 AM
UVA3rdGen's Avatar
any particular symptoms?
Old Sep 15, 2000 | 11:18 AM
Viking's Avatar
Car: / 89 IROC /
When mine broke I noticed that under heavy acceleration there would be a loud BANG.
89 IROC original owner, 3 amplifier 8 speaker Kenwood/Infinity sound system, 300,000 miles on original 305 TPI. Change your oil!!!
http://members.bellatlantic.net/~viking88/iroc.html
Old Sep 15, 2000 | 01:05 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your shifter will move up and down a lot.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 15, 2000 | 08:49 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Mash the gas with your hand on the shifter.It will move up and down more then normal. And if it is broken all the way,It will bang against the floorpan pretty loud.
Just don't punch the gas TOO hard.
Old Sep 17, 2000 | 07:55 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
when mine broke I could hear a grinding noise under hard acceleration.
my ujoint on the DS was slowly carving a hole in my frame
Old Sep 17, 2000 | 11:15 PM
Neo's Avatar
Neo
When mine broke it felt like my right rear tire was jumping over a rock from I started from a dead stop.
Old Sep 18, 2000 | 12:01 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Well, my transmission "banged" around in the transmission tunnel under heavy acceleration! If you want to check and see if is broken, jack up your car, take a pry bar and see if you can move the rear of the transmission/the tail shaft area. If it's broken, you will also notice that the rubber portion of the mount will have separated form the metal mounting plate. If it's broken, I suggest you put in a energy susp. mount - it's pretty tough, I have had mine now for 3 years/5,000 burn outs!!
Old Sep 18, 2000 | 12:07 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Well, my transmission "banged" around in the transmission tunnel under heavy acceleration! If you want to check and see if its broken, jack up your car, take a pry bar and see if you can move the rear of the transmission/ tail shaft area. If it's broken, you will also notice that the rubber portion of the mount will have separated form the metal mounting plate. I suggest you put in a energy susp. mount - it's pretty tough, I have had mine now for 3 years/5,000 burn outs!!
Neil 383 IROC-Z: TFS heads/JE pistons 10.8:1/ 24lb/hr SVO inj./ Edelbrock Runners&Base/ Strange 12Bolt Diff./ Neil's Home-Built BulletProof 700R4+Vigilante 2800 stall converter & much more.........
Old Sep 21, 2000 | 02:31 AM
Ryan89IROC's Avatar
When I broke mine, like everyone said, under hard acceleration it sounded like something was going to come up through the floor. Get under the car and push up on the tranny to see if it is seperated. If so, buy the energy suspension one from summit, it is stronger than stock and costs half as much. They also come in cool colors so you have pretty stuff to look at when you're under your car.
Old Sep 21, 2000 | 09:31 AM
UVA3rdGen's Avatar
yes, pretty stuff! I have heard a lot of good things about engery tranny and engine mounts. I now think it is my tranny mount that is at the beggining signs of dying and not my torque arm. Thanks guys
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
