problems pressing berings on eaton
Old Jul 8, 2008 | 09:33 PM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
So, i bought a new eaton diff, and tonight tried to press the carrier berings on it. they are new made by ratech (pn 3001K) problem is is that the berings will not seat all the way down. has anyone had any probles with this .. eaton is PN 19599-010.
im thinking that it may just be the poorly made japan berings
i made a crappy paint illustration to show that the eaton has a slight radiuos on it, but my bering is flat.. im sure that is the problem but what bering should i use?
Old Jul 9, 2008 | 05:07 PM
DM91RS's Avatar
Car: 91 RS
Re: problems pressing berings on eaton
I thought Ratech was a good supplier.....wrong. I could have gotten Timken's for less at Advance.
BUT......... just yesterday I had no problems pressing mine on a new Torsen. The same bearing kit as you posted.
Old Jul 10, 2008 | 05:30 PM
88tpi350's Avatar
Car: 88 formula
hey can you still take any pics of that, id like a side shot seeing the top of the bering, or do you have any part of where the axles slide into sticking out beyond the bering?
Old Jul 10, 2008 | 06:12 PM
DM91RS's Avatar
Car: 91 RS
I can take a pic. But I'm not sure what you want.
Old Jul 10, 2008 | 06:46 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here are a few shots of the bearing on my old Eaton.
I would have taken shots of the other side, but that side is broken.
The ear where the bearing presses on sheared off.
Old Jul 11, 2008 | 06:21 AM
88tpi350's Avatar
Car: 88 formula
exactly what i needed, thanks.. your bering is pressed on about 1/8" further than mine will go.
Old Jul 11, 2008 | 07:47 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Sounds like you have the wrong bearings?
Old Jul 11, 2008 | 08:47 PM
88tpi350's Avatar
Car: 88 formula
no, its correct bering, just crappy manufacturing. i got some made in usa berings today and they look a lot better
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
