I need clutch info!
I need clutch info!
My car is an 89 305 tpi with the t-5. I am swapping in a monster 383( 480ft/lbs and 420 hp) and I need to find out what clutch I need to get. I was looking at the center force dual friction clutches from JEGS. They however are asking what flexplate diameter and and clutch spline numbers I need. I need to know this can anyone help me out? Will this help to keep my engine from ripping the **** out of my t-5 until I can get it rebuilt?
Robert
1989 GTA TRANS AM
305 TPI, 5 SPD
SWAPPING TO TPI 350 NEXT MONTH.
Robert
1989 GTA TRANS AM
305 TPI, 5 SPD
Car: 4
Engine: 6
Transmission: 5
I have had the CF DF clutch behind the 400 in my 83 for some years now; this is the 2nd one, and I'm quite happy with them. It's a good choice IMHO.
You need the stock replacement configuration for your car, which is 10.4" and 26 splines. That's the only size that will fit inside the 3rd gen bell housing.
In fact, having a clutch that hooks up hard will enable you to destroy your trans faster, not the reverse. A T-5 will be a maintenance item behind such a motor (speaking strictly from experience). Rebuilding it doesn't help, the fundamental problem is that the parts are too small, particularly the case is too weak. It stretches under large loads enough to allow the gears to misalign, which of course causes rapid wear. Shock loading (produced by dumping the clutch at a stop, and speed shifting) is the worst possible stress on it.
Thanks for the information. I am on a tight budget putting in this motor. What can I do to try and beef up the tranny to last a little longer behind this engine? I want to switch to a T56 tranny but I don't have the funds to do this right now. I dont plan on taking the motor above 3,000rpm's while I am breaking it in. After that I will take it easy on the trans until I can get the T56. The trans has 160,000 miles on it.
1989 GTA TRANS AM
305 TPI, 5 SPD
1989 GTA TRANS AM
305 TPI, 5 SPD
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I love it. Are you gonna go to the F-body vs Mustang Shootout at Carlsbad Raceway on Oct 8th? If so I'll see you there! I didnt know you were local to me.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
If you're planning to change over to a T-56 get a cheap remaned clutch, it'll suck, but that's half the point. Unless you plan to get a re-drilled T-56 you'll probably end up switching the flywheel and clutch to an LT1 set-up. Those kind of numbers are really really pushing a T-5 and you won't be able to do a complete break-in on the motor as suggested by most automotive engine producers. The hard accelerations will murder it. Perhaps you should delay engine installation until you can afford a tranny that can hold up?
'84 Trans Am
Crate 350 - 4 bolt main, Holley 600 w/vac. secondaries now open element
T-5 - Stock with Zoom clutch and PP
'84 Trans Am
Linson
Oct 1, 2015 09:50 PM
