2nd gen rear gear question
Old Sep 19, 2000 | 07:51 PM
TINFY Racing's Avatar
ok guys and girls. i have a 79TA with a larger ten bolt(8.5"?) 2.73 rear gear and i want 3.23s. can i just change the ring and pinion gears or do i need or should i change the spider gears and bearings and what not. the car has 61K original miles. also are the gears from GM itself as good as aftermarket. can i get so pros and cons about going with GM gears. Thanks TINFY
Old Sep 20, 2000 | 04:31 PM
ede's Avatar
ede
i'd buy a gear set and a install kit. it has all you'd need, bearings and such. the spider gears should be fine to not replace.
Old Sep 20, 2000 | 09:42 PM
I dont need to change the carier do i? i know the housing is big enough but what about the carrier.TINFY
Old Sep 26, 2000 | 09:40 PM
btt
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
