how to know you transmission mount is broken
Old Sep 21, 2000 | 09:54 AM
92RS25TH's Avatar
i think my transmission mount might be broken, what are some ways to tell? when i get on it from a start, it is fine in first gear, but when i shift to second gear and get on it, something hits the bottom of the floor, sounds like right by the rear of the tranny. Are there ways to tell just by looking at it? And about how much would a new one be?
92 RS 25TH aniversary
flowmaster & k&n, now with a hypertech chip,also a 160 thermo, and a cold fan switch, and also a B&M ripper.. and looking for more mods to do
shaun
Old Sep 21, 2000 | 10:17 AM
andrew350's Avatar
sounds like you broke it to me.
I had the same symptoms a while back, so I took my car to my local tranny place. They inspected it for free (put it on the lift), and sure enough, it was split in two.
But it is very hard to see the break when the car is on the ground or on jack stands in my opinion.
But I'd bet you've broke yours. About price, you can get some stock rubber ones at AutoZone for cheap ~$10 BUT if I were you I'd get a polyurithane peice from summit or jegs. I don't know, probably around $20-30.
They're not too difficult to install, so don't let the tranny place tell you different.
Old Sep 21, 2000 | 12:15 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I had the same thump in my bird w a ES tranny mount, it ended up being the secondary cross member mounts, one of them were ripped in half. One last thing ES doesn't recommend mixing rubber motor mounts and Poly tranny mounts. Thats why this week I just finished, putting ES MM's, tranny and secondary crossmember mounts.
Later
John
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering,Lakewood LCA's,15X9 Centerline Warriors 275 50R15's BFG Drag Radials
Best 8th et 8.81@80mph.
[This message has been edited by spud (edited September 21, 2000).]
Old Sep 21, 2000 | 08:24 PM
chevyii's Avatar
I had to replace a broken trans mount on my 87 Z. You can normally tell if its broke by opening the hood, put the car in drive with your foot on the brake and SLOWLY press the accelerator. You should be able to see the back of the engine lift slightly. Mine has the torque arm that extends from the rear end housing. I'm sure that helps to lift. I don't know if this test would work on a car that's not equipped with a torque arm.
Old Sep 21, 2000 | 10:26 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i agree with them..sounds like you definitely broke it. when i got my car i had a bad tranny mount. when i got on the gas hard, all i heard was "BANG BANG BANG". not a good sound. but it is exactly what you said...sounds like a bang on the floor near the tranny. they are REALLY easy to do. a frined of mine that worked at a local chevy dealer brought the car in the stall, lifted it up, and it literally took like 3 minutes. very simple installation.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Transcooler
Brian's 1991 RS
Central NY F-Body Association
Old Sep 26, 2000 | 06:47 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
it also could be besides the mount being bad is the bolts that mount the mount to the trans are vibrating out. in my car i hear the same sound you did and the mount was gone but the bolts were very loose as well. then a week later i heard the same sound i went under there,took out the bolts that were loose again and put a lock washer on each.
it could be from be smoken the tires i dont know?
Old Sep 27, 2000 | 09:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's how to tell:
1. Do you have a 3rd gen Camaro or Firebird with a V8?
Yes = proceed to #2
2. Have you put a polyurethane one in it?
No = it's broken
Easy, huh?
These cars have the stupidest imaginable design in that area, they always break. My 83 with a 305 could break a brand-new one the absolute first time I stressed it. It only costs about $20, just do it.
Old May 13, 2013 | 01:16 PM
Camaro-King79's Avatar
Engine: 350 bored .040 over
Re: how to know you transmission mount is broken
I was wondering about my mounts as well bc I hear a lot of noise, bt only wen I run it n reverse? Is tht normal for a transmission mount???
Old May 27, 2013 | 09:15 AM
transam357jim's Avatar
Car: 85 built ta
Engine: 350 vortec roller .040 517 lift how
Transmission: 700r4 2800 stall
Axle/Gears: stock 291 need 411
shaun
its broke ive broken 3 of them it should do it if you punch it in 1 st mine did don't buy the new 1 from advance
Old May 27, 2013 | 10:06 AM
It's always good to see the new members do a search rather than asking the same old questions that have already been answered a million times, like every week or so, and all that; but I hope you guys realize, the original post is now 13 years old.
The forum has a setting for "oldest first", or "newest first". It's best to leave it set on "newest" so you're not replying to posts made before half the people on here were born.
Old May 27, 2013 | 10:46 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
true.
I like Put the car on stands and jack the transmission up!
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
