T5 shifting rough/slight grind
Old Sep 23, 2000 | 06:21 PM
sdevine's Avatar
Only in third and fourth. Its got 103k miles on it. When i shift into third/fourth, it feels/sounds like its grinding a bit. My master/slave cyclinders were new in january, i dont know whats up.
Old Sep 23, 2000 | 06:27 PM
Gunmetal's Avatar
My t-5 is f'd up too. My syncros are shot. All of my gears don't come together smooth. They don't grind, but I can feel a grinding sensation in shifter.
Old Sep 23, 2000 | 07:35 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Rebuild it, i rebuilt mine, smooth as a baby's ***
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Sep 23, 2000 | 09:58 PM
sdevine's Avatar
I've never rebuilt anything lol - I was going to attempt to buy a rebuilt one, and install it myself - how hard would that be to do with basic garage tools (what is necesary to buy?)
Should i just get a world class for a v6? What would happen if i put a T56 in a v6?
Actually, if anyone near NJ wants to make some money and help me i'd be willing to do that - I have to learn this stuff.
Old Sep 23, 2000 | 10:09 PM
sdevine's Avatar
Another thing i noticed weird, was after being in traffic for 2 hours, the metal park of the E-brake was warm- Ive never noticed it being warm, could that mean the tran. was running hotter than it should have been?
Old Sep 28, 2000 | 02:33 AM
Ryan89IROC's Avatar
As far as swapping the tranny, it is easy to do with just a socket and wrench set and a floor jack. Follow the instructions in the haynes manual except for removing the rear springs for the torque arm, that's not necessary. I've had so much trouble with my t-5 I can pull it out and put it in in about an hour and a half by myself.
Old Sep 29, 2000 | 03:22 PM
RegalEagle86TA's Avatar
About the parking brake handle... Check the lower rubber shift boot. I have heat coming up there if the windows are open because it draws a vacuum and that boot has a rip. After all, the catalytic converter is right there and operates at what, 1400F? So check that before worrying about the transmission.
1986 Trans Am
LG4, T-5, otherwise stock.
Saving money to upgrade to a TPI 5.0/T-5 in a year or two.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
