No wide open throttle into overdrive?
Old Sep 30, 2000 | 10:13 PM
85ZZ4TPI's Avatar
I replaced the sleve that keeps it from doing it, What could I have done wrong? The replacment was from art carr. Also does any one know what top speed would be with 4.11 gears and a 700R4?
Old Oct 1, 2000 | 01:58 AM
IrocManiac's Avatar
What do you mean??? Is it just not downshifting or are you free spinning the motor or what???
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 1, 2000 | 03:40 PM
89IROCZ
Guest
Posts: n/a
As far as the top speed goes with a 4.11 and a 700R4...
There are a lot of factors that go into it. Going by the calculator's on this board though it should be somewhere around 137mph. That is assuming you have standard tires, and that you can get to the ZZ4's readline (5850) in your final gear. It will be real hard to get to 5850rpm though in a .7:1 gear, especially wiht TPI when you are moving that fast. Having said all that, you could probaly do 125-130 with a 4.11, 700R4 and ZZ4.
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Oct 2, 2000 | 04:57 PM
85ZZ4TPI's Avatar
No it just wont shift from 3rd to 4th when I have it redlined in 3rd. I have to lift off the gas.
Old Oct 2, 2000 | 05:00 PM
85ZZ4TPI's Avatar
My redline is around 5000 rpm with my stock TPI on there.
Old Oct 3, 2000 | 09:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did you align the sleeve properly? If I remember right, the sleeve could be turned 180 degrees and still "fit" into the valvebody.
Also, did you reset your TV cable adjustment?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
