Great, what did I break now
Old Oct 1, 2000 | 08:48 PM
cobrakiller1989's Avatar
Can someone please tell me what is wrong with my car, It wont shift from 2nd to 3rd it just revs up like its in neutral, its a 700r4
thanks ahead of time
Old Oct 2, 2000 | 10:16 AM
Birmass's Avatar
When I did my 350 swap the same thing happened to me. I have no idea how, but my 3rd and 4th clutches got burned up. It would be fine from 1st to 2cd, but if I let of and tried to cruise it would only rev the engine like it was in nuetral. I might have over filled the tranny, but I'm not positive.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
Old Oct 2, 2000 | 01:07 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I also had that happen... I changed the fluid in a "panic" (It had been almost 2 years since I changed it, when I usually did it every year), and two days later, all I had was 1st.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 3, 2000 | 12:11 PM
IrocManiac's Avatar
I have had the same thing happen to me. I had it rebuilt and it still did it. Then they found the problem and fixed it. My clutches burnt out that control the downshift from OD to 3rd and OD to 2nd and the one that controls the shift from 2nd to 3rd. Now my car is back in the shop because the Overdrive Sprag broke. I am fixing to post about that as a matter of fact. Anyways sounds like a clutch problem.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 3, 2000 | 06:07 PM
I figured it was a clutch problem but I was hoping it wasnt
Old Oct 3, 2000 | 09:03 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Cobra Killer, your 3-4 Clutches are smoked. They were probably on there last leg, and the swap was the straw that broke the camels back, or just poor timing, you be the judge.
IrocManiac, I know it isn't your fault, but everything you just said made no sense whatsoever. There are no clutches that control downshifts. If you want to learn about which clutches do what, go to my website in the sig and go to tech. I did an article on how to read a Clutch and Band application chart. I hope that will help. Also, there is no such thing as an "overdrive sprag". There is a foward sprag, and a low roller clutch. A bad foward sprag will cause no movement in OD, but there is no OD sprag. Overdrive is achieved simply, well, check out the chart.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
[This message has been edited by GMTech (edited October 03, 2000).]
Old Oct 3, 2000 | 11:53 PM
IrocManiac's Avatar
Sorry GMtech. Glad you were hear. I know a lot about motors and am trying to get used to this whole tranny thing. I am doing my best to learn but it is very complicated. That is what I was told was in those tranny's obviously I was wrong. Thanks for the correction.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
ktthecarguy
Jul 5, 2020 11:46 AM
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
Chevy3shitty
Sep 1, 2015 02:10 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
89fast5oh
Aug 24, 2015 08:14 AM
