Pulling Bearings & Pinion from 9-bolt?
Old Oct 8, 2000 | 06:54 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I'm ready to pull the pinion out of my 9-bolt rear, and once I get it out pull the pearing. Also ready to pull the bearings off the axles.
Anyone have some advice on doing this? Looks like I'll need some special tools. The pinion won't just tap out of the yoke - it's ON there. Axle bearings may not be that bad, but I hadn't tried yet.
Advice sought,
Craig
Old Oct 8, 2000 | 07:03 PM
ede's Avatar
ede
i put the nut on the pinion and drive it with a brass hammer, you can't reuse the nut anyway so it doesn't matter if you trash it or not. to get the bearing off the pinion i use a bearing seperator and a press. the axle bearings will fall out more or less after you take the seal out of the axle tubes. i use a puller for the bearings on the carrier.
-=ICON MOTORSPORTS=-
lt1z350
Sep 29, 2015 01:50 PM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
86IROC112
Aug 31, 2015 07:00 AM
red90IROCls1
Aug 25, 2015 06:56 AM
89fast5oh
Aug 24, 2015 08:14 AM
