clutch affecting engine pressure
Old Jul 22, 2008 | 07:16 PM
kccisco's Avatar
Car: 85 transam
Engine: 76 chevy 350 carb
Transmission: t-5 3.23
i was driving down the highway at 85mph and when i came to a stop on the off ramp i couldnt shift into 1st or 2nd gear in my car and when in tried to put it into reverse the gear started to grind. well im prety sure that it has something to do with my clutch but heres the puzzler. when i come to a stop after riding at 85 mph and the gears wont go in, i also notice that my presure guage shows my engine pressure at zero even though the engine has the right amount of oil and the oil filter is good.i put the car at 1000rpms and the oil pressure comes above 0. i drive this car everyday and it never shows the engine pressure at 0 if i dont ride the highway. any help would be nice because i have no idea how my clutch would affect my engine pressure
Old Jul 22, 2008 | 07:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: clutch affecting engine pressure
your clutch has no effect on the oil pressure.
The sender or gauge could be going bad. If not, its the oil pump and your motor will be toast shortly
Old Jul 22, 2008 | 11:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Oil pumps almost never go bad, but if it did and the oil pressure actually was 0, you'd know it immediately from all the ugly noises the engine would be making.
Old Jul 22, 2008 | 11:27 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Yeah the noise is instantanious... if you change the oil + filter, and start it up the first time, it will be loud for a few seconds untill the oil primes, and then it quiets down immediately. Thats what it would sound like driving, except worse.
Old Jul 23, 2008 | 06:50 PM
kccisco's Avatar
Car: 85 transam
the reason i thought it was the clutch was because that the engine runs fine in town but becomes weird only when the clutch doesnt stop. in town i will run the car to 3500-4000rpms sometimes and ill drop some rubber on the road but when im driving on the highwy only doing 2500-3000rpms and come to a stop the pressure drops. this is just puzzling me
Old Jul 23, 2008 | 09:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The pressure drops after you're stopped, or while you're stopping?
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
R3500
Aug 17, 2015 12:16 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
rsrmoore
Aug 7, 2015 08:44 PM
