will calipers from a 9 bolt disc rearend work on a 10 bolt disc rearend??
Old Oct 14, 2000 | 04:45 PM
bad camaro RS's Avatar
i am swapping out my 9 bolt rearend with disc for a 10 bolt disc the ten bolt is missing a caliper can i use one from my 9 bolt on the 10 bolt thanks
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
2000 tci stall
700R4 with B&M shift kit
Old Oct 14, 2000 | 05:28 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Yes, it could work, but are you talking about using just the one nine bolt caliper and keeping a ten bolt caliper on there too ? If so, I would go ahead and swith them both.
You will need the backing plates off of the 9 bolt. You will have to modify the backing plates by filling the bolt holes in and redrilling the holes to match the 10 bolts pattern.
Sparks a flyin'
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
