I want to put a stall converter in my car and i was thinking like 3000 but might go with 2500. I kinda want to go with the 3000 b/c i will be gitting a new engine. What do you guys think?
thanks
keivn
thanks
keivn
How about you just start 1 thread and keep with that one instead of putting 4 threads on here in different places about the same thing.
You need to match your stall to your cam. Get the cam card and see where its suppose to making power. If you still cant figure it out call the cam manufacturer.
what motor are you workign with and whats all done to it? whats the purpose of the car? track alot for ET's? or street driving mostly?
ok it will be 350 made into a 383 stoker with 475 at the crank. It will not really be ran on the track but will be raced. I want to say i have an 11 sec car.
kevin
kevin
3000 stall easily then. no less. i'd prefer 3400
Ok but if i went with a 3400 or what ever would my 305 take it?
kevin
kevin
Quote:
kevin
it would be abit much for a bolt on 305. 305 i'd go 2800 and no more for bolt ons. more modded may want 3200 but shouldnt take much more than thatOriginally Posted by GoodlookinRS
Ok but if i went with a 3400 or what ever would my 305 take it?kevin
i mean you can get away with 3400 on a 305 for alittle while, and actually a 3400 stall designed for a 383 will stall lower on a weaker 305 so you probly could run that converter just fine for alittle while before the motor gets in
Ok then im looking at like a year or so before i get my engine so mabey in 6 or 7 months do something like that with headers and a y-pipe.
thanks
kevin
thanks
kevin
well if its gonna be a year i'd just wait to get the converter with the new motor
or get a 3000 to have a little fun for now and laterHow much sould one cost then to install one?
kevin
kevin
converters are 200-1000 depending and installation at a reputable tranny shop shouldnt be that much. they should beable to bang it out in a hour or two but i'd bet they would charge 100-200 bucks labor,etc, but its hard to say. I never got it done seperately. It cost me 1000 in cash to rebuid my tranny with good stuff and install the converter at the same time
So i should be able to do it for 500-800 bucks! Now if i do it a few months be for my engine will it really be hard on my 305? When i come off the line from a stop sign or somewhere will it really move?
kevin
kevin
it may be harder on the trans and make it heat up more while its unlocked and the rpms are up. SHould be ok tho.
yes it will be completely different car if you havent driven a car witha converter in it before. From a rolling start its definately fun. becareful from a stop, car may want to loose traction alot quicker than your used to
Add an aftermarket trans cooler with the higher stall converter.
