will firebird rear swap into camaro??
Subscribe
Oct 11, 2000 | 09:25 PM
I think it will, but let me know for sure.
Thanks,
Kelly
Reply 0
Oct 11, 2000 | 09:57 PM
Yes it will they are the same thing.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Reply 0
Oct 12, 2000 | 05:38 AM
it most certainly will, you have to remember that these cars were all built from the same parts
Reply 0
Oct 12, 2000 | 03:32 PM
Maybe what I forgot to ask was...will the rear end from a 93 firebird swap into my 88 IROC-Z? Someone said something about needing new rims if I tried it.
Kelly
If you've gotta fix it, fix it better than stock.
Reply 0
Oct 12, 2000 | 04:51 PM
Yes, but the 93 rear end is 2 inches wider than your current rear end. Your 88 rims will bolt up, but might stick out slightly passed your fenders.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Oct 12, 2000 | 09:05 PM
Actually it's 2 inches wider per side.
Reply 0
Oct 13, 2000 | 12:18 AM
pretty much everything under the fenders is the same in camaros and firebirds (the interiors are differnet, yet they will bolt up). Its always been that way..hell, my passenger door is fro ma camaro :P
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
35X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Reply 0
Oct 14, 2000 | 02:24 PM
So...is it gonna look like s h i t?
Reply 0
Oct 14, 2000 | 07:29 PM
Ever see s dodge neon or nissan maxima with 13" spoke rims that stick way out on each side? that will be you. Like mentioned, the rears are almost identical EXCEPT the width. 4th gens have a different offset than 3rd gens.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Reply 0
Oct 16, 2000 | 04:59 PM
Damn...what the hell can I do? I know 4th gen rims won't fit on the front of my car. They rub. Do they make replica IROC rims with the correct offset? If so who do I ask for them? What about putting "front" IROC rims on the back of the car...might just make it worse, but I know there's something different between the front and back IROC rims. Any help would be appreciated.
Kelly
Reply 0
Oct 16, 2000 | 06:56 PM
Just get fourth gen rims. Alls you need is spacers on the front and your set. Take a look at the topic on rims in the appearence board. Good luck
Reply 0
Subscribe
