Vibration and no TCC lockup related?
Old Oct 12, 2000 | 10:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TCC hasn't locked up since I got the car running. I have no idea of its history except 123k miles on it. The pan was fairly clean when I put fresh fluid in before driving it. The rest of the drive train seemed well maintained as well.
It has an engine-speed related vibration that gets pretty noticable above 2000 RPM. When you really get on it, it seems to smooth out some but shakes pretty good when you back off while the RPM's are still up. I'd describe the vibration as a combination shake/shutter. Other than that, the tranny works well and hasn't given any problems in 11k+ miles over the last 13 months.
I know the solenoid is getting power. I'm not completely sure the rest of the circuit is working, but I don't have any reason to believe it isn't. It would sure be nice if just changing the torque convertor would cure both the vibration and lockup problem.
Oh, I didn't split the engine and tranny when I did the swap. There was a rattling noise that had gotten worse lately, which went away when I tightened up the torque convertor bolts last night.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 17, 2000 | 04:51 PM
five7kid's Avatar
Guess no one has seen anything quite like this.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
92camaro350cci
Oct 14, 2015 09:29 AM
ramicio
Sep 28, 2015 01:18 PM
roysatikas
Sep 22, 2015 08:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
