can someone explain this to me?
Old Jul 26, 2008 | 03:36 PM
Nater2491's Avatar
I just purchased a new posi and gears out of an 87 iroc and im looking for a new diff cover and gasket. My question is,what size rear end do i have? i keep seeing them at 7.5 & 7.625 . i have an 86 iroc z that currently does not have posi and what i beleive to be a 2.73. o and its tpi if that matters . any help is appreciated
Old Jul 26, 2008 | 04:12 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: can someone explain this to me?
that would be a 7.5 inch rear but most covers for either or are interchangable. Since the bolt patterns are the same.
Old Jul 26, 2008 | 05:41 PM
Nater2491's Avatar
ok thanks for the help
Old Jul 26, 2008 | 06:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not just the bolt patterns, everything is the same.
Old Jul 26, 2008 | 07:51 PM
Nater2491's Avatar
if everything is the same, why do they have different names>?
Old Jul 26, 2008 | 08:16 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Gm likes renaming things
Old Jul 26, 2008 | 08:20 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
.... Trust me i work at a gm dealership, and everything has like 4 diffrent names and it always is the same part just different car.. Its a big pain when trying to get parts from the parts shop and they all give u a odd look then u name off the 3 other names and they finally relize what you are talking about.
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Some of the 10 bolts have ring gears that are 7.5", and some are 7.625". The extra .125" makes no difference to anything else, and the two different sets are interchangeable.
Usually the 10 bolt is just referred to as the 7.5" rear, and it's understood that this includes the possibility that the ring gear may actually be 7.625". If there is explicit mention of 7.625", it's almost always together with the 7.5", as in "7.5/7.625" differential".
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Cacike
Aug 27, 2015 05:10 PM
