will my stock flywheel work on new engine
Old Oct 18, 2000 | 12:07 AM
JJ's Avatar
JJ
I want to use the stock flywheel off my '87 LB9 on my current 350 (gmpp vortec headed engine). I just had it turned today but figure I had better make sure, the balancing crap is confusing to me . . .
thanks
Old Oct 18, 2000 | 04:26 PM
ede's Avatar
ede
if the old flywheel is for a 1 piece seal and the new engine is it'll work. you can't interchange parts between 1 piece and 2 piece seal engines.
-=ICON MOTORSPORTS=-
Old Oct 18, 2000 | 07:17 PM
JJ's Avatar
JJ
cool, thanks . . . the more I looked at aftermarket units, the more I grew concerned about internally/externally balanced engines and flywheels. I'm going one piece rear main to one piece rear main though . . .
Old Oct 18, 2000 | 07:18 PM
84FTA's Avatar
As said you can't use them inbetween engines. Here are the reasons why:
Two piece rear main SBC's use a neutral balance flywheel, except for the sb 400 because there isn't enough room for counterweights on the crankshaft. Two piece rear main seal flywheels also use a 3.58" crankshaft. These were used until 1986/1987 depeneding on car model
One piece rear main SBC's use a counter-balanced flywheel and have a 3" crankshaft.
These rules also apply for chevy V6 engines.
Flywheels and flexplates come in both 14" (168 tooth) and 12 3/4" (153 tooth) sizes. You can fit both flexplate sizes into a 700-R4 which will give you more mechanical advantage thus giving you more torque. However, you can't fit a 14" flywheel into a T-5 bellhousing without bellhousing modification which in any instance (high stress) where you'd use a 14" flywheel the structual stability of the bellhousing would be comprimised. It would be better to use a lakewood or similiar SFI approved bellhousing for these applications. Two piece rear main seals, albeit more leaky, are recommended for heavy duty applications.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
