LT1 and 700R4...???
Old Oct 15, 2000 | 06:53 PM
IrocManiac's Avatar
LT1 and 700R4...???
I am thinking of getting an LT1. I have talked to one person taht bolted it up to his 700R4. Then I had this place tell my I had to use the 4L60E is this true??? It can't be if the other dude had it bolted to a 700. I just had a new 700 put in mine witha corvette servo and a stage 1 shift kit so i want to keep it.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 15, 2000 | 08:50 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The 700 is also called a 4L60, wich is the NON-electric version of the 4L60-E. The internals and bellhousing are identical between the two, but you will have to use a '93 ECM becuase it was the only year for the 4L60 to be bolted to an LT1, in '94 and later, it was the 4L60-E so the ECM is different to accomodate the extra electrical components in the transmission.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Oct 15, 2000 | 10:56 PM
IrocManiac's Avatar
Cool that is what I thought. I thought they were the same tranny but wasn't sure.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Old Oct 17, 2000 | 01:40 AM
Curse Z28's Avatar
if you get a '92 LT1 from a corvette you could use its ECM also, they had the 700R4 also.
i have heard that the corvette's LT1 is easier to swap in (not to mention better) and that you want to use the accessories off of the vette engine as they fit better in the thirdgen engine bay.
Old Oct 17, 2000 | 12:38 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
You CAN use a '94-'97 LT1 computer if you want, you just have to rig up a manual torque convertor lockup switch. That's it, just make sure you get a PCM that's for an M6 or else the computer will throw codes because it can't shift the tranny.
Old Oct 17, 2000 | 12:40 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Also the '94-'97 PCMs use a MAF sensor versus the speed density setup, and the MAF sensor LT1s are known to respond to mods a bit better than the Speed Density ones.
Old Oct 18, 2000 | 12:25 AM
IrocManiac's Avatar
Thanks again guys!!!
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
Old Oct 18, 2000 | 07:57 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Markloc, Yes, you CAN use a '97, but unless you want to have to deal with **** emissions, I wouldn't reccomend it. Also, in '97 (I think '96 too) they used MAF and MAP at the same time. Thank Big Brother and OBDII for that.
South East Thirdgen
Savannah, GA
'97 Bonneville SSE
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
