rear end code help please
Old Oct 17, 2000 | 07:00 PM
spitfire350's Avatar
i have the code 2HA on my rear end and there are some #'s there too and i was wondering if anybody knew what this code meant. and does any body know what would be good to clean of all the road crap on my rear so i can see the #'s better thanx
keep the stang's far behind u and the cops even farther
Old Oct 17, 2000 | 08:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The rest of the numbers have to do with the date and place the rear end was made.
2HA = 1987 3.23 gears
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
[This message has been edited by Stephen 87 IROC (edited October 17, 2000).]
Old Oct 17, 2000 | 10:43 PM
thanx a million! but how do i know if i have posi or a limited slip???
thanx
Old Oct 17, 2000 | 11:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It's hard to tell from the axle code. Either open it up or check the RPO list. G80 is posi
Old Oct 18, 2000 | 03:55 PM
what is the major difference between posi and a limited slip? is posi both wheels at the same rate all the time?
thanx for the help
Old Oct 18, 2000 | 06:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The axle code should also indicate posi or open. I'm 1500 miles from my book, or I'd give it a shot.
"Posi" or "positive traction", limited slip, etc., are variations on the same theme. Different companies came up with their own name for their product. The posi differential has a clutch set-up to partially tie the two axles together to a certain torque differential, in order to keep the lower-traction wheel from spinning as much as it would otherwise. Some people would argue that a "locker" is a different type of limited slip that should be distinquised from "posi", but I'm not smart enough to say. The other possibility is a "spool", which is a solid mount for the ring gear to the axles - race only, not for street use, please.
Old Oct 18, 2000 | 08:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Posi is GM's name for a limited slip. Ford and dodge have their own names for it. A true posi uses clutches to hold both wheels until one starts to slip. You can tell a real posi by jacking up the rear end and spinning the wheels. They'll both turn in the same direction. GM also makes a locker type diff. The diff works like an open carrier diff and when jacked up the wheels will turn in oposite directions. Under power when one wheel starts to slip, locking dogs engage and lock the diff. Although this will apply power to both wheels, it's not as strong as a real posi. The best way to tell if you have this type of diff is to pull the cover off and look inside.
My 454SS truck has this type of locking diff and I've had no problems with it. I put over 400 pounds of torque through it and smoke both tires.
Best 60 foot: 1.662
Old Oct 19, 2000 | 03:26 PM
badbird88's Avatar
Quickest way I would find out is go on a dry highway and see if both tires spin !
if it is a GM posi then it should have a metal tag on one of the bolts holding the rear-end cover on which will tell you it's a posi along with the gear size. If your not the original owner and there is no tag then it could be different gears installed or just a posi added from the previous owner...who knows. All else fails then pull the cover and look on the ring gear for the gear size.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
