Tranny won't shift out of 1st!!
Old Oct 19, 2000 | 07:59 PM
Bruce89TA's Avatar
Car: 89 Firebird T/A
Hey Guys,
Well, last Saturday I'm driving on the service road and I feel a pop from the rear and I've lost power.. Hitting the gas doesn't give me any pick up.. I figured, I'd broken the pinion gear or the teeth weren't meshing anymore.
So I brought my car into the shop to get it fixed. Since the differential housing was damaged and got punctured by part of the pinion gear, the housing had to be replaced. It's been replaced now but now my car won't shift out of 1st gear. Is there something I need to check before I go out replacing the tranny? I'm thinking the accumulator might be stuck open.. I can't say for sure.. It does shift into reverse and 1st gear.. I think the planetary gears might have died but I can't say for sure without opening it up and looking.. Anyone have any idea what to check into and what the problem might be? Thanks.
-Bruce
89 Firebird T/A 305 TPI w/dying 700R4
Old Oct 19, 2000 | 08:08 PM
RP1987GTA's Avatar
Ck the Governer gear.....might be worn off ...it nylon ..plastic...easy to replace too
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:73s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
Old Oct 19, 2000 | 08:47 PM
Bruce89TA's Avatar
Oh, I also forgot to mention that I have a B&M shift improver kit in it. It's set to firm shifts.
Where might I find the governer gear? I assume it's in the tranny somewhere? I'll have access to a lift since it's at the shop right now.. If anyone could offer up some help, I'd appreciate it.. Thanks!
-Bruce
db057
Apr 28, 2019 07:45 AM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Formula_88AE
Sep 3, 2015 01:47 PM
