Clutch Problems (Pics Included)
Ok so I bought a 83 Trans Am, and the clutch wont engage. Of course I can start it in gear and power shift just fine. The guy I bought it off of said its the clutch cross-shaft and there are no parts linking to that. Here are some pictures of what I think the problem is not to familiar with Transmissions.
http://gallery.filefront.com/Damasterlordg/144437/
Im not sure with it can be just bolted to the frame or if that piece goes into a hole on the cross-member next to the back of the motor and pivots. Maybe someone has some hints on were to start.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Clutch Problems (Pics Included)
This still has the mechanical linkage eh?
You probably need to adjust it. Got a haynes for your car? They have the instructions in that. You loosen the locknut, and thread out the rod until you have ~3/4" of freeplay or so, then snug it back up.
Here's some pics
https://www.thirdgen.org/forums/tran...ighlight=z+bar
Here's some pics
Car: 1982 Trans-Am
Your pics didn't work on that goofy hosting page. Just post it on TGO here.
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
