rear swap.... Do i need a spring compressor.
Old Oct 25, 2000 | 07:41 PM
spitfire350's Avatar
i am planing a junkyard rear swap. i know that it should just bolt right in but what about the springs? do i need a spring compressor to get them off? Also is there a way to take off my original drums and put them on the new rearend so i dont have to bleed the brakes (I just got a brake job like 2 weeks ago). If anyone has a tech article on rear end swap i would be great. well thanx for the help
later,
ross
keep the stang's far behind u and the cops even farther
Old Oct 25, 2000 | 08:15 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
no, you don't need a ring compressor. just rest the car on stands, jack up the rear end, unbolt all the bolts, and lower the rear end and the springs will pop right out. Just be carefull, use a lot of safety precautions. Don't know about the brakes though. And yes, there is a tech article on this in the tech section.
Mods:Hooker Aerochamber 3" exhaust, gutted kitty,
March 2 piece underdrive pullies, smog pump gone,;these two made a very noticable difference.
14x4 K&N open air element filter-the best mod so far
Eibach springs with KYB's all around.
Appearance: Harwood cowl hood, Z-28 wing, painted black(7/20/00)-original color was light blue
*All these mods were made this year
Stock Options:117,000 miles on motor, 5spd, TBI, 305, T-tops
Run a best of 16.7 @85mph with traction problem. Have to try again sometime.
Old Oct 25, 2000 | 08:38 PM
ede's Avatar
ede
you should be able to unbolt the backing plates if you don't want to bleed the brakes.
-=ICON MOTORSPORTS=-
Old Oct 26, 2000 | 09:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
In fact that might be a better way to go (re-using your original brakes), since at least you know the operating condition of them.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 26, 2000 | 01:47 PM
thanx for the info.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
