Set up specs for Auburn Posi unit
Old Oct 27, 2000 | 03:48 PM
85NASTYZ28's Avatar
I lost the set up specs for an Auburn 3-series posi unit for, 26 splines. Also a friend sold me a 3.42:1 ring and pinion from a 1999 6 speed Z28. The gears fit. Does anyone have the factory set up specs for this combination. Any help would be greatly appreciated.
Old Oct 27, 2000 | 04:20 PM
ede's Avatar
ede
the back lash and pinion depth should be on the gear set. it's differant with every gear set made. not sure what you lost? the torque specs shouldn't be hard to find in most manuals.
-=ICON MOTORSPORTS=-
Old Oct 27, 2000 | 07:04 PM
JERRYWHO's Avatar
This is from drive train direct.com
Assembly Specifications:
Cover Bolt Ft. Lbs. 20
Pinion Brg. Preload In. Lbs 24-32
Pinion Brg. Preload In. Lbs 8-12 Used
Ring Gear Backlash .005-.009
Ring Gear Bolt to case Ft. Lbs. 90
Side Brg. Caps Ft. Lbs. 60
I hope this helps
Old Oct 30, 2000 | 09:28 AM
85NASTYZ28's Avatar
Thanks for the information. I now have an '88 Camaro sport coupe with a throttle body FI 305. I also have a 383 stroker that will soon be in it. The current rear end has 2.77:1 rear gears. Does anyone know if the axle has 26 or 28 splines? Any info will be greatly appreciated.
Old Nov 2, 2000 | 02:26 AM
JERRYWHO's Avatar
82-87 is 26 splines and 88 and up is 28 splines
92 Z28 5.7 TPI AUTO 105k factory motor and trans.
SLP headers and runners, B&M 2400 stall, shift kit,LCA brackets, EBACH spring kit, NITTO'S, NOS
best 60ft 1.87 1/4 12.48 @ 110.81
Old Nov 2, 2000 | 10:05 AM
Birmass's Avatar
If you have 2.77's then you have the diferent rear. It's not a ten bolt, it's a 9 bolt which I have heard is a pain to get gears for.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
Old Nov 2, 2000 | 10:36 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
'88 is s transition year on the axles. Some of 'em got the 28 splines...some 26. The only way to be sure is to open up the rear-end, pull the c-clip, slide the axle back a bit, turn the wheel and count splines, or just totally remove the axle (you've almost done it anyway.).
-Mark W.
'88 SC Camaro w/ 305 TBI
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
